Axles & Wheel Spacers
Old Aug 7, 2002 | 03:25 PM
727Banshee's Avatar
On a Raptor how long does it take to change the axle and is there anything I need to know about the durablue wheel spacers before I put them on when I get the raptor.
Old Aug 7, 2002 | 03:40 PM
Stealthraptor's Avatar
Check out sand sport wheel spacers @ http://www.off-road.com/atv/reviews/...ts/sand-sport/
Old Aug 7, 2002 | 03:52 PM
WarriorManiac's Avatar
I recently took me about 2 hours to put a DuraBlue Eliminator on my Warrior. The hardest part was beating the old axle out once everything was loose. It was kinda seized to the carrier bearings. If its a new bike you're going into, shouldn't be a problem. As far as the spacers go, be sure and read about making sure they are under compression once installed or they will fail. The ones for the Warrior it is not clear which way they go on. I think I have mine right? The flat wider edge with the relief cut in it toward the hub with the more rounded narrow edge toward the wheel.
Good Luck
Old Aug 7, 2002 | 04:22 PM
BJAZ's Avatar
I have a set of DuraBlue 2.5" spacers for sale that fit the rear of a Raptor. Let me know if you interested.
BRIJENAUS@AOL.COM
Old Aug 7, 2002 | 08:58 PM
727Banshee's Avatar
Bump
1000gade
Sep 9, 2015 04:41 PM
meddy0388
Sep 9, 2015 06:41 AM
bmark0610
Sep 7, 2015 09:42 PM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
