Tri Flow for chain lube
Old Aug 8, 2002 | 03:37 PM
fuddrucker's Avatar
Anyone ever heard of or used a product called "Tri Flow"?
A buddy of mine has been using it to lube his chain and it seems to work fairly well. I was thinking of trying it. It says it is safe for wood, metal, rubber, and is specifies it can be used for chains.
Thanks.
Old Aug 9, 2002 | 10:37 AM
95wolv's Avatar
Tri Flow is a great all-around spray lube. It has Teflon,so it is very slippery,and seems to cut rust good on parts like bolts,etc. We use it at work all the time on a lot of different stuff. It would lube a chain ok, but it is very thin,and would easily fling off after a short ride,plus the residue might attract dirt.You would be better off with the chain lube sprays like Maxima Chain Wax,or other parrifin base,which dries to a nice dry film,that won't attract dirt.
mrtidy
Feb 3, 2016 05:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
kbazzy
Sep 26, 2015 11:26 AM
bmark0610
Sep 7, 2015 09:42 PM
