beartracker mods?
Old Aug 11, 2002 | 01:16 AM
yammy660r's Avatar
has anybody done any mods to their beartracker?
Old Aug 16, 2002 | 01:00 AM
doggster's Avatar
There arnt too many things you can do to a beartracker. But what you could do it order a FMF mega max pipe, get a K&N air filter, or the the carb jet kit. Also it depends on what kind of poweryou are looking for. If you want more top end you could buy a taller tire but make sure it is light, something sporty not a mud tire. Also with a taller tire you will lose some low end power. But if you want low end power buy a shorter tire like maybe a 20 or 21. With those you will be spinning alot. Personally I like low end power so I would get smaller tires. So you can throw some dirt and rocks at the guy behind you. If I were you I would get a Titan Fast Trekker. They dont come in 21's though.Only 20's so you would lose a bit of top end. So if I were you I would get 23's or 24's (make sure they dont rub) then the pipe,jet kit and air filter. So that way you pick up more top speed with the tires and with the pipe and filter and jet kit you will pick up more power to turn those tires. Good luck
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
