Wolverine
Hello,
I am just curious as to how you all like your wolverine's.
Do any of you have any major problems with them? What is the issue with 3 wheel drive I have heard about? Also, if you ride several miles on paved roads what kind of tires will last the longest and still be ok for mud/snow? I have heard that these quads will go 55-57 mph is this true? Because if they have the same engine as the warrior you would think the 4x4 would slow it down considerably.My only worry is running on the roads at high speeds for deveral miles and wearing something out.
Thanks Steve.
Thanks Steve.
Hello, The Wolverine will hit speeds around to where you mentioned, and the stock tires would most likely be ok for riding on pavement and they shouldnt where down much unless you turn alot and skid on the pavement. Those tires might not be the best for mud or snow but they should get the job done. Oh and the 3 wheel drive is called
DIFFERENTIAL. This is when only 3 wheels spin ( the front 2 alternate) which makes it easier to control when turning the power may be going to the inside front wheel. I am not quite sure of How this will work when only driving straight but I know it'll go fast and has good amount of power.
