I think I have Fuel Problems
Old Aug 14, 2002 | 02:43 PM
doggster's Avatar
I have ha my 4 wheeler for about 2 years. I have never had any problems with it. A few days ago I went riding with some friends and i came home and parked the 4 wheelr like always do. The today when went to start it and it startedright up. Then onc I let I warm up I rode off and it was spiting and sputering. I thought it was thePlug so I go anewplug and put it in. It seeme to run bette for a few minutes then it ran lie crap again. So I put in alittle dry gas and that didnt help any. So what do yu guys think it is?
Old Aug 14, 2002 | 06:28 PM
desracers's Avatar
maybe water in your gas tank that might be causing? From a batch of gas where you got it. You might want to drain the gas and put a new gas in it. See if that help. Float might be stuck?.....
Check all the plugs and see they are connect.
Old Aug 14, 2002 | 10:36 PM
flattracker's Avatar
Check your air filter! If it is clogged up with dirt your bike will "choke" itself out. I try to clean out my air filter about once a week. Depending on what kind of conditions I am riding in.
Old Aug 14, 2002 | 11:42 PM
doggster's Avatar
Yeah thanx for the input guys. Yeah I will have to check th float I am hopinh it is that because it is something I know how to fix. What I really dont want is it to be a burned up valve. Talk about some coin.
Old Aug 15, 2002 | 12:10 AM
lonestarbanshee's Avatar
I'd check the air filter before tearing into the carb..
Old Aug 15, 2002 | 06:01 PM
doggster's Avatar
Today I took out my 4 wheeler and it ran OK. But Stllt wasnt 100%. I adjusted the air in take screw to the carb and I think that helped alittle. But now I am woundering if I adjsted the valves if it would do anything. What do you guys think?
Old Aug 15, 2002 | 10:52 PM
desracers's Avatar
It wouldn't hurt to check it out..... Never know the valves might be tight.
micheleLeigh
Jul 12, 2015 02:50 AM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Mikea1978
Jul 4, 2015 12:37 PM
