Raptor: Parking brake block off...
Old Aug 19, 2002 | 12:39 PM
eman4000's Avatar
could someone please post a picture(link) of this block off, as i just bought mines and wanted to see the finished installed part on the Raptor. thanxs.
-eddie
Old Aug 19, 2002 | 01:07 PM
2fiftyX's Avatar
I don't have any pics but I just installed my nac's block off this weekend, it looks pretty trick. It is just a cap on the inside of the brake caliper mounted with the two bolts that use to hold the parking brake assembly.
You will need to remove your front plastic to remove the switch on your handle bars. I cut the two wires after the connection behind the radiator and electrical taped them up SEPERATLY (if they make contact the quad will think the parking brake is on and not run properly).
To remove the cable you will have to take the adjustment screw off at the handle bar end, remove the bracket on the back side of the motor (the bolts also holds your starter in position), slide the bracket off and put the bolts back in. After poping the cable out a couple J-hooks that holds it in place, you should be able to pull the cable right out the back.
Old Aug 19, 2002 | 05:32 PM
RaptorRyan's Avatar
eman4000- You should be able too see it in one of theese pics. www.bikepics.com/members/raptorryan.
Old Aug 19, 2002 | 05:57 PM
BlueLeader's Avatar
here you go eman4000....Picture
Old Aug 20, 2002 | 01:27 PM
eman4000's Avatar
thank's everyone.
Old Aug 20, 2002 | 03:11 PM
klj's Avatar
klj
BlueLeader,
How does the block off seal against the caliper? Is there an O-ring or gasket? Do you reuse the original gasket?
Thanks in advance.
Old Aug 20, 2002 | 03:14 PM
BlueLeader's Avatar
I used a thin layer of permatex to seal it.
1ArmBandit
Sep 8, 2015 08:59 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
