HEY 660 GUYS PLEASE HELP!!!
Old Aug 19, 2002 | 10:58 PM
badfordman's Avatar
With a K&N and a pipe what jetting changes are needed when I remove my airbox lid?
THANKS!!!!1
RIDE-ON!!!!
Old Aug 19, 2002 | 11:26 PM
14mins's Avatar
what is your elevation?
Old Aug 20, 2002 | 12:22 PM
gjeff80's Avatar
It will just require re-jetting, if you are taking you air box lid off, causing more air to get in, you will have to jet up to make it run richer!
Glenn
Old Aug 20, 2002 | 07:04 PM
2002grizzly660's Avatar
IF you are taking the airbox lid off of your Grizzly 660 airbox, you will run the chance of the air fitler popping up and not being in the right spot to filter the air. The lid holds the filter in place, so by removing it you are asking for trouble.
Just drill the airbox lid with 7-9 1" holes, this is a very safe way to get alot of fresh air into it.
You will probably have to go up a jet size to adjust for the added air....if you are running a dynojet 155 now, you should go to a dynojet 160.
Steve
Old Aug 20, 2002 | 07:28 PM
badfordman's Avatar
Hey 14min,
I'm at 1000 ft sea level.
Hey steve,
I dont actually run without my airbox lid. I cut the snorkle down each side, then pried the opening apart (making it larger) then filled in the gaps with plastic welder.
I also drilled a bunch of quarter inch holes in my gastank cover (just above the snorkle) to let fresh COOL air in.
Now the problem is I think it's getting too much air.
Do I need to go to the 160 jet?
RIDE-ON!!!!!!!!1
Old Aug 21, 2002 | 01:50 PM
badfordman's Avatar
Hey prorider,
When you say 25p are you talking about the pilot jet?
bafisher1986
Jul 21, 2015 04:12 PM
rcappie4
Jul 18, 2015 07:51 AM
Robinhood
Jul 13, 2015 09:13 PM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
