Drag setup for the raptor...
Old Aug 21, 2002 | 01:07 AM
RaptorRcR's Avatar
We'll see how well it works this Friday at the track...
Thanks to Moose for the design idea...I hope he doesn't mind me copying most of it[img]i/expressions/face-icon-small-smile.gif[/img]
The pics are high res...so 56k users beware..
Raptor1
Raptor2
Raptor3
Raptor4
Old Aug 21, 2002 | 01:20 AM
14mins's Avatar
you scared me off with the beware. Same bar or reworked? What track are you headed to??
Old Aug 21, 2002 | 01:32 AM
mxzxracin's Avatar
Nice job on it... You should paint it...
Old Aug 21, 2002 | 01:34 AM
RaptorRcR's Avatar
Same bar I had before. I modified it so it's adjustable now, and alot sturdier. I'll be out at Kennedale on friday. I believe Ronnie is going, and maybe Justin. I've heard of a few others going..but Im not too certain. I'm sure Chris and Bob will head out as usual [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 21, 2002 | 01:36 AM
RaptorRcR's Avatar
mxzxracin..it is painted. It's hard to tell though. When it is in the sun, it sparkles and doesn't look so dull. The paint came out darker than I had planned on, so I may take it down to the bare polished metal like I had it before.
Old Aug 21, 2002 | 01:37 AM
14mins's Avatar
I will miss. I am going to kerville for the week end. I have no idea about Bob. He left for Arkansas (CSR) today with some heads and usually stays until they are finished. I am headed up when the next batch of valves arrive.
Old Aug 21, 2002 | 01:44 AM
Ward660R's Avatar
Nice, is it for sand, dirt, or asphault?
How is it adjustable?
Old Aug 21, 2002 | 01:52 AM
RaptorRcR's Avatar
Ward...it's adjustable for all. I have it set real low for asphalt this Friday. When I get in the dirt, I raise it up off the ground and put the shocks back on. Riding on dirt with no front shocks would be brutal[img]i/expressions/face-icon-small-smile.gif[/img]
The bar running up to the shock mount is hollow..and I found a piece of solid steel that fit in it and drilled 3 holes at different distances on the bar. I bolt it in to the hole that will set the wheelie bar at the right height for what I am riding on.
Old Aug 21, 2002 | 04:06 AM
THEMOOSE's Avatar
Be sure to post your times & how it runs.
Don't forget to shift your weight towards the rear when you launch since you won't have as much weight transfer with the struts!
Old Aug 22, 2002 | 12:41 AM
Ward660R's Avatar
I see I couldn't tell. Just a thought, it looks like you are using a flat profile tire, on the asphault I would think something more rounded would be easier to keep straight. I have my bar built but haven't had the time to try all the stuff out.
