cutin up the air box
Old Aug 21, 2002 | 08:24 PM
hoeryder's Avatar
raptor 2001-proflow foam filter-yoshi full comp pipe-2''x7'' inch rectangle hole on top of the lid with outerwear-altitude 1000 feet getting ready to put the pipe on and rejet i have gotten a lot of good information from the threads about jetting.Greg v, your pictures helped out a lot.thanks.first of all,im using mukuni jets.the main jets i have figuered out.should i be woried about the pilot jets?go to a diferent size?any other tips would be apreciated.does any one think a hole in back of the box would help or hurt.pretty tight there.somebody once said something about air turbulence in the box. just thinking if one more hole somewhere else would prevent that. or is it just a myth? thanks. one more thing, what are the stock pilot sizes .
Old Aug 22, 2002 | 05:06 PM
garyc660R's Avatar
A hole in the rear of the box will add a tad more air.....on mine, the only Noticable difference is with no lid at all + proper jetting. The Pro-flo set-up with no lid does create turbulence.....this can be fixed by leaning the needles a tad.....at least thats what I had too do with mine.
Old Aug 22, 2002 | 08:10 PM
GregV's Avatar
I glad the pictures helped. [img]i/expressions/face-icon-small-smile.gif[/img]
Stock pilots are 22.5's...........I would recommend leaving them alone. I went up to 25's when I went to my 686 set-up, but I'm going back. From what I understand the pilots are primarily for the idle function. I'm rich in idle and lean on top. So, I'm going back to the 22.5's and bumping up the mains.
You will like the Yoshi pipe.
Good Luck!!
Old Aug 24, 2002 | 12:52 PM
hoeryder's Avatar
Thanks.
Old Aug 24, 2002 | 01:17 PM
warrior007's Avatar
Chimmer has the same setup with the back of the box cut out, yoshi pipe and proflow. He has had many problems but since he cut the back out it seems better @ 1/4 thottle. Its killer on top though, gobs of power.
Old Aug 24, 2002 | 02:50 PM
QuAdRaCeR775's Avatar
how many post untill i become a trail blazer???
Old Aug 24, 2002 | 03:06 PM
BlueRulez's Avatar
quadracer, I think it's 20.
Old Aug 24, 2002 | 03:17 PM
o
Old Aug 24, 2002 | 04:50 PM
redriderman's Avatar
Do you guys know how many posts it takes to become a pro rider or whatever or what i dont really understand.
Old Aug 24, 2002 | 05:36 PM
GregV's Avatar
I believe it's somewhere around 200 posts for Pro Rider.
