Wont stay in gear
Old Mar 21, 2000 | 09:24 PM
MaineRider's Avatar
have a 96 sport 400 when you put in forward and take off it kicks out of gear.. doesnt do it in revese HELP
Old Mar 21, 2000 | 09:30 PM
mudmachine's Avatar
Zippy... Its one of two things... Either your shifter is WAY out of adjustment.. Or the shift dogs in your transmission are just worn out.. If its the latter of the two, they aren't that difficult to replace..
Old Mar 22, 2000 | 10:41 AM
Hawkman's Avatar
Sounds like you need to adjust your shifter arm.
This is the piece that runs from the bottom of your shift lever to the top of the transmission, and looks kinda like a tie rod. Loosen the lock nuts and spin the rod either in or out. You can watch the shifter handle move as you turn the rod. You want to see the handle moving towards the rear of the quad, this will give you more travel in the shifter handle. Once it is adjusted, remember to tighten the lock nuts back down.
Old Mar 22, 2000 | 07:49 PM
MaineRider's Avatar
Thanks for the input.. I tried to adjust it but it didnt help.. even took linkage off and put in gear by hand just keeps popping out of gear. Gonna try what Mud said and see if the shifting dogs are worn out.. Ordered a manual today now just have to wait for snail mail to arrive.
merryman
Sep 6, 2015 10:20 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
ScopeZ_
Jul 28, 2015 01:44 AM
black_thunder
Jul 26, 2015 09:23 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
