how often to change chain/sprockets
Old Aug 31, 2002 | 02:36 AM
elmascrambler's Avatar
how often should a scramblers chain and sprockets be replaced.
Old Aug 31, 2002 | 04:05 AM
modquad's Avatar
Keep an eye on the profile for wear...that's monitoring the wear of the links as you look at the chain from the side. If it's stretched too far and won't properly tension up when you adjust it. If you have frozen/stiff links.
As far as sprockets, the front one is the one that'll make you pee your pants when it goes. The sound of that sprocket grrrrrinding as it jumps teeth on the trans output shaft will make you think you lunched the trans.
I normally replace both sprockets and the chain at least once a year. After every good hard riding weekend, the quad gets washed up and a 'postflight' inspection. Lube and adjust the chain so it's all ready to go next time. Try Tri-flo spray teflon on your chain, stays really clean and works great on the tie-rod ends too.
Hot Seat, sells the Sunstar sprockets and some good chains. I'm sure Rick Ritter, and HPD could also hook you up.
Ken
Old Aug 31, 2002 | 04:12 AM
I've had my quad for a little over a year and i ride it hard so i should be due. you think i should use sunstar sprockets? what about a new chain?
Old Aug 31, 2002 | 05:11 AM
modquad's Avatar
I would change the front one out....they're pretty cheap. I always coat the splines of the new one with anti-sieze. Take a good look at your chain. If you're not running too high a HP, I wouldn't worry too much about it....watch it though. Just give things a good look over, you'll see where they are wearing.
Ken
Old Aug 31, 2002 | 05:28 AM
Thanks for the info.
Old Sep 1, 2002 | 03:32 PM
scramblered's Avatar
it make me sick,i change them (sprockets) every 2-3 months,but that was with no chain tensioner,now i've got the tensioner and i set it properly to hold the chain and the sprockets seem to last better longer as well.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
