Clunking Sound
Old Sep 1, 2002 | 11:56 PM
02Scrambler500X's Avatar
only some times, it clunks really loud sounds like its comming from the belt area. only does it when im going between 10 and 45 or so
Old Sep 2, 2002 | 01:38 AM
talonhawk's Avatar
Maybe one of the weights is sticking or binding. The next time it starts
making that noise. Take the clutch cover off and start it up. Make sure
its in neutral and parking brake is on. Revve it up a few times and
see if it still makes the noise. While its running you should be able
to see if the belt is binding in anyway and that the primary and
secondary clutches are operating okay or not!
Old Sep 2, 2002 | 09:11 AM
Northstar2's Avatar
I've had clunking sounds when the chain gets too loose on my Scram 500. I'd check there too. Actually, my chain is always loosening up, don't know why.
Old Sep 2, 2002 | 01:10 PM
buffalosoldier's Avatar
Northstar -- I have clunking sounds/loosening chain on my Scrambler too. I took the chain guard off, and now the chain stays nice and tight. (Gonna replace it with with of those nice metal ones). I'd be sure that your chain guard is adjusted right. Anyway, the clunking sound stayed. Looks like a messed up link. Looks like I gotta replace the chain too!
Old Sep 2, 2002 | 11:12 PM
Northstar2's Avatar
how could the chain guard loosen the chain? I will check it, but I dont get it. Is it okay to run it without the guard on?
Old Sep 3, 2002 | 02:30 AM
I took the cover off and the primary cluch is ticking really loud thats it. I drove it around the yard but it wouldent make the clunking sound with the cover off, Theres wear groves from the belt on the back of the cover is this normal? is it normal for the sprocket on the tranny to wiggle about 3/8in. cuz mine does and theres metal shavings every where from the sprocket and the chain? THANKS FOR THE HELP! does anyone know the difference between a scrambler and a scramblerX ? besides the color and the wheels
Old Sep 3, 2002 | 02:47 AM
modquad's Avatar
Are you sure your clunking isn't coming from your front sprocket "skipping" over the teeth on the trans output shaft. If there's lot 'o' shavings, I'd be changing out that front sprocket...it's just held on with a snap-ring.
Ah, you shouldn't have "rub" marks inside your clutch cover, but sometimes when we come down from airial adventures "whahooo!", we might bump, kick, land on it. I'd do my best to make sure it seems "centered" and not rubbing.
I did an unintentional 'Big Air Superman'...wasn't with the seat grab, I was hanging onto the bars for life....once on a road-crew modified ditch crossing. Some riders passing by in a car caught up with me later, they said my feet were WAY up over my helmet. They commented how cool it looked, then I commented on how accidental it really was. HOLY PUCKER FACTOR BATMAN!!!!
Anyway, landed on the clutch cover, and Ohhhh what a racket.
Ken
exmotocrosser
Sep 13, 2019 06:12 AM
flyin-lowe
Dec 1, 2017 03:18 AM
mrtidy
Feb 3, 2016 05:00 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
