2001 Scrambler 400 2x4 question...
Old Sep 2, 2002 | 09:13 PM
Screw's Avatar
I don't have the manual. Can someone tell me how the chain is adjusted. I didn't see any obvious adjuster nuts like you'd find on a dirt bike. Thanks...
Old Sep 2, 2002 | 10:28 PM
WhiteLightning's Avatar
First you need to loosen all the carrier bolts for the axle including the brake just loosen not take out. then incert a screw driver in one of the sprocket holes until it grabs the hole on the hub you need to rotate the axle while doing this so you can find the hole. Once you found the hole it is just a matter of turining it in the right direction. good luck
Old Sep 4, 2002 | 11:40 AM
Screw's Avatar
What exactly am I turning; the hub?
Old Sep 4, 2002 | 12:14 PM
pudljumpr's Avatar
yes, you are turning the hub. you can also use a pipe wrench once you have the 4 bolts loose. Turn it so the grease zerk moves toward the engine, that is tightening it. When it won't tighten anymore, bring it back just a little, and you should be about right!
98 xplorer 400 k&n,, boysen reeds
02 scrambler X 4x4
Old Sep 5, 2002 | 01:11 AM
Screw's Avatar
Thank you.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
exmotocrosser
Sep 13, 2019 06:12 AM
35dodge
Sep 29, 2015 09:40 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
