2 stroke problem please help
Old Sep 4, 2002 | 12:41 AM
duster's Avatar
My engine will not do much more than idle. When I try to rev it up it wants to die. As I let off it runs normal again. There is no miss at all. But, it does seem to be running a lot hotter than normal. I have tried a new plug and adjusting the plug gap but this doesn't seem to help. All inside the carb appears to be clean. What could be my problem?
Old Sep 4, 2002 | 01:36 AM
modquad's Avatar
Hey Duster, sorry to hear about your problems. What engine, any mods?
Ken
Old Sep 4, 2002 | 04:29 AM
BeastyTrailblaizer's Avatar
sounds like it could be a carb problem. my 00 tb was doin sumptin like that and it was all in the carb. has it been messed with lately?
Old Sep 4, 2002 | 10:48 AM
walexa's Avatar
First, I would check the carburetor bowl. It probably has some water in it. If no water and the rest of the carb is clean, I really don't know what it could be other than maybe a plugged exhaust.
Waylan
Old Sep 4, 2002 | 03:45 PM
the carb may be flooding out at anything more than idle if you increased the jet size try going to a smaller one or a different needle position or the carb may just need the air adjustment screw cranked out a bit. but it sounds most likely like its flooding out check your jetting
Old Sep 4, 2002 | 05:18 PM
scramblered's Avatar
jetting too rich or too lean depending the weather you are at...
Old Sep 4, 2002 | 07:12 PM
beastytrailblaizer,what do you mean by "custom forced air intake"?
does it work?what is the performances or utility gains?thanks,later...
Old Sep 4, 2002 | 08:33 PM
modquad's Avatar
Like to see a pic...hope the forced air doesn't include water, mosquitos, small furry animals, or other quads..hehe
Ken
Old Sep 5, 2002 | 08:58 AM
ive blocked off everything below the upper framerails to keep all the heat from the engine away from the intake, and after i did that i figured it wouldnt be hard to direct all the air directly to the airbox intake. so with some plastic and a soildering iron to mold it all to gether i made a "funnel" type thing so to speak that forces all the air to the airbox intake
kelleycully
Sep 15, 2016 02:57 AM
SDR-II
Sep 29, 2015 01:06 AM
NatePerz
Jul 27, 2015 03:27 AM
ghost3
Jul 19, 2015 08:46 PM
