bike will not start if i let it set up over a day. please help
Old Sep 4, 2002 | 11:39 PM
maximus's Avatar
on my 400 2 stroke i have been having a problem starting my bike after it sets up for a day are two. i can full choke it and pump the throttle a couple of times and it might start. if it will not start, i have to unscrew the choke where it goes into the carb and raise it up and then it will fire right up. once it starts it does not have a problem starting for the rest of the day. but you let it set up for over a day then you have to go to the same procedure again. i am running amsoil 80:1 with premium gas and a iridum tip plug. carb settings is 30 piolt jet, air screw 1 1/2 turns out, needle in 2 notch from top, 200 main. i live in Lousiana. I also put in a new needle and seat back in july
Old Sep 5, 2002 | 12:55 AM
JoshCVBz's Avatar
Sometimes my 400 sport would get vapor locked just sitting for some reason. It started doing it right before I sold it, but it never did it before that.
As soon as I would open the gas cap it would fire right up...if I didn't I could try all day and not work.
Might not be your problem, but just something to check.
-Josh
talonhawk's Avatar
It sounds like your choke is out of adjustment. Check the color of
your plug if you get it started again.
Old Sep 5, 2002 | 09:49 AM
maximus's Avatar
thanks will do. on the choke cable the plunger how far does it need to be in.
Old Sep 5, 2002 | 09:54 AM
Mike Chero's Avatar
maximus,
I have this happen all the time on my Sport. The cure is to shut the gas off and run the float bowl almost dry before you put it away. You can tell when it is almost dry when the idle starts to pick up. Then just remember to turn the gas on before you start it again and you'll be fine.
Old Sep 5, 2002 | 10:03 AM
JoshCVBz's Avatar
Hey Mike,
Who's the 250ex you have for?
-Josh
Old Sep 5, 2002 | 10:25 AM
Mike Chero's Avatar
Piranha,
My kids. I originally bought them a used (and much abused) Trailblazer. Well, even after getting the motor rebuilt, I knew it would be nothing but trouble as most kids don't take care of things. So I went out and bought the most maintenance/trouble free machine out there. I suppose I could have gotten them a Recon, but I did want to get them something sporty, so the 250EX it was. They haven't had a problem with it besides twisting the handlebars in the clamps after they rolled it (twice). Nice reliable little machine. I can't say much for the handling, power or suspension, but these things don't matter much to kids. Just as long as it goes.....
Old Sep 5, 2002 | 10:34 AM
JoshCVBz's Avatar
Mike,
I hear ya there...The 250ex is basically the only quad in it's category left.
I'm sure the kids love it...sounds like they've been doing some freestyle action.
Old Sep 5, 2002 | 11:25 AM
talonhawk's Avatar
Maximas
The book says 1/8 - 1/4 of an inch cable free play. The free
play is measured at the choke toggle lever, between the lever
and the top of the screw portion (big black nylon nut that holds
the lever to the console).
Old Sep 5, 2002 | 12:36 PM
maximus's Avatar
thanks
whitty
67
Feb 24, 2021 02:52 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
Bassassasian101
Jun 10, 2015 06:23 AM
1000gade
May 27, 2015 12:37 PM
Codyv20
May 26, 2015 09:51 AM
