300EX will not go in neutral
Old Sep 7, 2002 | 11:21 PM
jola's Avatar
My 2001 300 EX will not go in neutral most of the time. I checked the free play on the clutch handle and it seems to be OK. What should I be looking for?
Old Sep 9, 2002 | 06:40 PM
300exRiderJay's Avatar
1 out of 10 times mine wont go into neutral but if you turn it off it goes in easily.
Old Sep 9, 2002 | 06:50 PM
2fastandfurious4U's Avatar
Mine does that all the time. I have been thinking about taking the tranny apart and finding out. I'll let you know...........
-Ben
Old Sep 10, 2002 | 12:35 AM
HondaEXtreme01's Avatar
yeah my 300 is real hard to put in neutral while its running to. but a method i use to help it get into neutral while running is to take a bungie cord and pull in the clutch handle and wrap it around. this releases the pressure on the clutch packs and makes it easier. i do this whenever i don't ride and now it will almost go into neutral everytime. something to try at least.
Old Sep 10, 2002 | 10:55 AM
fuddrucker's Avatar
Same here.
I have a 96 and a 98 300Ex and neither one of them likes to go into neutral 75% of the time. Usually, I will just hold the clutch in, turn off the power, and then put it in neutral. Goes in real easy that way. I think it is just a 300EX thing.
Old Apr 16, 2003 | 12:56 PM
ovriderex's Avatar
Default 300EX will not go in neutral
i have an 01 and half the time it dosnt wanna go in but i just shut it off and it goes in real easy
Old Apr 16, 2003 | 01:53 PM
hutchies's Avatar
What do you need neutral for?[img]i/expressions/face-icon-small-happy.gif[/img] LOL
Old Apr 16, 2003 | 05:32 PM
01TRX300EX's Avatar
Mine does that to, my dad a mechanic) says that one of the clutch plates might be warped, which would cause that. Since Honda isn't exactly known for strong clutches, that would be my best guess.
Old Apr 17, 2003 | 09:30 AM
dzzy's Avatar
High idle speed causes hard shifting into or out of neutral especially. Sometimes it helps to disengage your clutch and move forward a couple inches, then try again.
Old Apr 18, 2003 | 09:05 AM
Puddles00's Avatar
