fuel leak
Old Sep 8, 2002 | 06:39 PM
HAZ's Avatar
HAZ
my fuel tank on my scrambler has a small fuel leak on the bottom where the fuel lines come out of the tank. what can i use to fix the leak?
Old Sep 8, 2002 | 06:43 PM
95wolv's Avatar
If you mean around the fuel petcock,you should be able to drain the tank,remove the petcock assembly and replace the gasket around it. If there is an actual hole,it will need to be repaired, there are several chemical tank repairs out there,just don't use Kreme, the coating eventually comes loose,and plugs up your carb or filter.
randymack
Aug 24, 2015 05:47 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
Unzzy66
Jul 11, 2015 10:01 PM
