Foreman tow ball???
Old Sep 11, 2002 | 08:35 AM
2strokesrule's Avatar
Can you put a standard tow ball on a 2002+ foreman ES with the need of some kind of receiver?
Old Sep 12, 2002 | 10:51 AM
trx450's Avatar
I believe the axle hitch is sufficient to tow anything you would want to, within reason. It was heavy enough to do anything I needed around my place. Firewood , boat,mower-- it pulled 'em all. Mine was a 2K, but the rear axle is the same.
Old Sep 12, 2002 | 12:43 PM
maddog56's Avatar
you sure can. the foreman will even pull a small travel trailer, 25ft or less, around an rv lot!! just watch for that front end to come up
Old Sep 13, 2002 | 02:01 PM
action450s's Avatar
I towed an INGERSOLRAND construction site lighting plant with mine with no problems!!
Old Sep 14, 2002 | 01:22 AM
dusty1's Avatar
Helped a friend move two deer stands today with my Foreman. I use a standard 2" ball in the hole provided with the ATV. We pull a small trailer and then tilt the deer stand over onto the trailer and then haul it through the forest anywhere we want. The stands weigh probably 500lbs. We were tilting one of the stands back, up which put weight on the back of the trailer. I looked back and the rear tires on my Foreman were up in the air about 12 inches. My friend said "well we now know the hitch on a Foreman is strong.".
I have also pulled trucks out of mud holes with it, pulled boats, even plowed my food plot at my deer stand with it this year. It will pull just about anything.
Ted
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
mark23
Oct 1, 2015 09:57 AM
patrick.oc123
Sep 15, 2015 02:45 PM
89Lt250r
Sep 7, 2015 07:53 PM
