squeeking noises????
Old Sep 13, 2002 | 11:36 AM
BLAZIN325TrailTank's Avatar
Why does my 00 Trailboss suspension squeek the way it does? Is there anything I can do to make it quit? It is very irritating.[img]i/expressions/face-icon-small-frown.gif[/img]
Old Sep 13, 2002 | 12:36 PM
brent87LT1's Avatar
Could be the top of the front springs or the bushings up there. Take the nut off the top and put some silicone lubricant on them (not the spray type). Them put some in the top few coils of the springs.
Old Sep 13, 2002 | 12:38 PM
The rear sounds louder than the front
Old Sep 13, 2002 | 02:35 PM
Is there anything I can put on the rear shock to quiet it down?
Old Sep 13, 2002 | 03:35 PM
brent87LT1's Avatar
Is it the shock that is squeeking or the spring?
Old Sep 13, 2002 | 04:25 PM
Farmr123's Avatar
First, be sure the suspension zerks are greased. If the squeak seems to be coming out of the shock area, it is usually the ends of the shock, where the bolt goes thru that squeaks. High strength silicone lubricant did the trick for my Xplorer. Just spray it in the joint the best you can, and work the suspension up & down. Keep doing this until it quiets down. Remember the bushings in the shock ends are some sort of plastic or synthetic rubber, so don't use oil on them, as oil will soften them, and cause them to weaken, likely wearing them out quicker.
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
firsttimerider
Sep 20, 2015 09:07 PM
