Ccrambler 500 airbox & oil?
Old Sep 14, 2002 | 12:49 PM
ScRaMbLeRiZeD's Avatar
Me and my friend were out riding just before when it came to a halt because he fliped his machine. It was leaking gas as i expected it to. But when we got it back over we noticed a lot of oil. We opened the airbox and there was a pool of oil. Whats the cause of this? I don't think this is supposed to happen. Any replies will be helpful. Thanks.
Old Sep 14, 2002 | 12:50 PM
It is a scrambler 500.
Old Sep 14, 2002 | 12:56 PM
400x's Avatar
Scared to death of girls!
I can only assume that the Scrambler is similar to the Sportsman. If so, then that is from the oil overflow. My dad had that problem with his, and we didn't have any idea why. After it sat flipped over for 1/2 hour, his air box was full of oil. We cleaned it out, put in a new air filter, and it was good as new. Someone we ride with told us that is what happened. Personally, I don't understand why you would put the over flow there. Hope that helps.
Scott
Old Sep 14, 2002 | 03:07 PM
ftwflh's Avatar
It is normal just clean the air box and put in a new filter ,check the oil and take off.
Old Sep 14, 2002 | 05:13 PM
scrambled6910's Avatar
Big Sigh of relief. Yep I knuckle headed around a turn and lost traction. I took a dive off the machine and it landed next to me. I managed to get out of it with a bruise. I hate tree stumps with a vengeance. Thanks a Million guys, i thought there might have been something really wrong.
Matt
Old Sep 14, 2002 | 10:47 PM
KAWAZUKI's Avatar
You may have a k&n air filter that you oiled to much and it filled your air box drain plug.when the quad flipped all the oil whent the wrong way up the tube.
Old Sep 15, 2002 | 12:30 AM
Nah it's definately motor oil. Theres no way the blackish green is anything but a syntec motor oil. Thanks Though. Machines running fine.
Old Sep 15, 2002 | 02:14 AM
PolarisMech's Avatar
the negine crank vent is plumbed into the airbox, and when ya hold em upsidedown, the oil in the engine will travel up the tube and into the airbox.
But..the 500 is a drysump engine that carries MOST of it's oil in that metal container on the side (where you fill it with oil)
soo you won't starve the engine of oil if it does go upsidedown.
just clean out the airbox, and check you oil level.
1986Vmax540
Jul 9, 2021 09:53 PM
Canamaniac!
Sep 15, 2015 06:19 PM
mbriggs
Sep 13, 2015 10:47 AM
Dammar
Aug 26, 2015 07:12 PM
ghost civic
Jul 20, 2015 12:36 PM
