removing primary
Old Sep 18, 2002 | 12:10 AM
filthyhabit's Avatar
Anyone know how to get the primary off without purchasing the puller. Ive seen people hear saying something about using a trailer ball and threaded rod. Has anyone tried this?
Old Sep 18, 2002 | 12:32 AM
400fnSport's Avatar
I've mentioned it on here before. I used a 2" trailer ball that was fine threaded. Then use a 3/8" extension with a socket. Stick it in the shaft coming out of the primary, and screw in your trailer ball. The bolt on the ball will press on the ext. which presses on the shaft, as the ball pulls out on the clutch, and then it will pop right off. I've done it many times with this method.
Old Sep 18, 2002 | 05:34 PM
shopman's Avatar
Buy a puller you don't have to mass up the threads with the ext. about $14.00
Old Sep 18, 2002 | 05:57 PM
called 61 marine and sports in hastings mn today they want $35 for a puller
Old Sep 18, 2002 | 08:50 PM
LOCOMOFO's Avatar
where can you get a puller for 14.00???
I paid 34.99 through dennis Kirk??? cheapest i found???
and I don't think the trailer ball trick wouldnt have worked on mine.... someone must have used an impact to get it on[img]i/expressions/face-icon-small-mad.gif[/img]it did not come off easy!!!
Old Sep 19, 2002 | 12:47 AM
Randrball's Avatar
hot seat performance sells them for $20. use the ball and extension with socket method. just tighten down on the ball with a pipe wrench until you meet extreme resistance. now just take a hammer and lightly tap on the ball. presto it will take off the most stubborn clutches.
Old Sep 19, 2002 | 04:12 PM
SurferSam's Avatar
Make sure you buy the trailer ball with the smaller 3/4" diameter shaft.
SurferSam
Old Sep 19, 2002 | 04:31 PM
modquad's Avatar
Make sure to remove the ball before riding..hehe, so you don't hurt your own.[img]i/expressions/face-icon-small-smile.gif[/img]
Ken
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
WilliamBos
Sep 6, 2015 10:53 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
