Trailblazer chain?
Old Sep 22, 2002 | 12:34 PM
CallMeBubba's Avatar
How do I adjust the chain on my 01 Trailblazer? I have no idea where my manual went.
Old Sep 22, 2002 | 02:19 PM
Conkster's Avatar
It is real easy to do all you have to do is. Loosen the two bolts on the axle carier and the two bolts that hold the rear disc brake on to the axle carier. Then you just stick a screwdriver in the hole thats in the back sprocket the hole will let the tip of the screwdriver go in the axle carier. Rotate forward to tighten and backwards to loosen it.Then just retighten everything back up.Make sure you tighten the axle carier bolts to 60 foot lbs. Hope this helps.
Old Sep 22, 2002 | 05:41 PM
Thanks for the info. When you say roll forward to tighten do mean roll the whole quad?
Old Sep 22, 2002 | 06:00 PM
MossMan84's Avatar
Yea, that's what he means, but I always just use a pipe wrench to turn the whole thing. You can do it either way.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
chewy78
Sep 8, 2015 10:37 AM
bmark0610
Sep 7, 2015 09:42 PM
