help
Old Sep 24, 2002 | 12:37 AM
djmac379's Avatar
finally jetted my sons trx 250x. it was idling perfect but was lean on between 1\4 to 3\4 throttle so i went to move the clip on the throttle needle. it was already at the richest setting so i put the carb back together and when i started it back up i lost the idle. i mean no idle speed at all. if i turn the speed screw it has very little effect. this is the second time this has happened when i open up the carb to adjust the needle i lose the idle. i have it running very well at speeds above idle (main jet from 28 to 38) turning the idle mix screw has no effect good or bad. it is like the idle circuit is missing. any ideas?
thanks dan
