Anyone race MX on their DS?
Old Sep 27, 2002 | 11:31 PM
Kodiak01's Avatar
Im thinking of doing MX on my DS next year what all would u suggest I buy for it. Also if you have any good tips on setup & riding techniques.
Thanks
Old Sep 28, 2002 | 12:27 AM
buttfungus's Avatar
I would at least get some good aftermarket +1 forward and +1 wider a-arms, uppers and lowers with some good front shocks to go with them. Come on mx'ers help him out!
Old Sep 28, 2002 | 12:33 AM
mxzxracin's Avatar
I know a guy that now has a z400 but, he had a ds and he raced in wisconsin, and he took 2nd over all!
I dont know how he is doin on the Z but i guess, he was hella good on the ds.
I ride on mx tracks alot and I have drove the raptor and the ds on the track and i love the ds, raptor i dont like so much
Old Sep 28, 2002 | 01:35 AM
hoover650's Avatar
I ride some MX...18x11x10 holeshots 19x6x10 Holeshots on .190 aluminum...
go ahead and order a $12 UNI pod filter (carburetor direct mount)...these tires help a lot...a 17" f/sprocket will give you good low end while still keeping an awesome top end..I race my DS on MX tracks and do pretty good..and im also little 15yrs old, 120lbs, 5'9...these tires are the #1 advantage on your competittion. If you have the money to order cams...that would help a lot. Ron Woods would do the trick, I also ride with a Pro Circuit, that is an awesome low end pipe for MX. On setup i like my Toe set straight up...i dont know about others....with the toe set straight up it corners on a rail...thats just me...I also like my suspension soft front and rear with a lot of rebound in the rear... Learn to ride with your front brakes,transferring weight and back the pig into every turn. Have fun!
Old Sep 28, 2002 | 06:09 AM
BillDS650's Avatar
Get a - 1 inch swing arm you will be able to turn quicker and be able to lift the front end easyer.
Old Sep 28, 2002 | 12:26 PM
AdamsBadDS650's Avatar
Well, I disagree on the A-arms, unless you have $600 that you absolutely have to spend. I like the width of the DS, and I don't see a point in widening it more. I do agree that a set of Holeshot tires, a good set of cams, maybe a Hi-comp piston, and carb, and definately shocks would be good.
For cams, Piston, and a carb I would check out Ron woods racing, at www.rotax.net. they have some good choices. Don't get the TM45 carb, it looses low-end, which is critical for MX, go with the TM42 carb.
Shocks, I have heard of people bending works shocks, so for a moderately priced shock, I would look at Elka, or TCS.
Holeshots are best for MX, and 18's would give you the best accelleration, and low end, but you might get dented rims a little more often, because the DS hubs will not fot 8in rims, so the tire protects the rims less. If it were me, I would go with 20in Holeshots.
Also, a good clamp-on UNI filter will let the beast breath better.
Oh, I almost forgot, nerf bars! Get you a good set of Graydon nerf bars, everyone will tell you the same, don't even look for a different kind, just get the Graydons
Old Sep 28, 2002 | 12:28 PM
I also like the idea of the -1 swingarm, better turning, and it will save some weight.
Old Sep 28, 2002 | 12:35 PM
buttfungus's Avatar
The reason I suggested aftermarket a-arms is that with the abuse that mx gives your machine, alot of the stock pre-baja a-arms have the tendency to break the front shocks because of incorrect front end geometry. Pay now or pay later, the choice is yours. Ride safe!
Old Sep 28, 2002 | 02:07 PM
MadBaja819's Avatar
I race a MX series here on my BAJA and love it and I'm doing quite well with my setup as listed, I also have the Holeshot 19x18 setup!!!!! Big help there, this winter I will be doing alot of work in preparing it to run both MX and XC next year, I will also be adding Works Shocks.
Old Sep 28, 2002 | 03:12 PM
Ds650RaCeR's Avatar
Adam,
Speaking of Nerf Bars i have some for sale!Quadboss Nerfs Yellow!any one want them???email me at ds650_racer@hotmail.com and i will send you a pic...i will probaly ask about 65-75 for them..
Tate
