tire inflation for rubicons
Old Sep 30, 2002 | 01:11 PM
jaffrican's Avatar
the max inflation (as specified on the tire) for my stock 2002 rubicon is 36psi (think they're bridgestones). i use the machine primarily around the farm to do chores - any recommendations on tire pressure?
incidently, i think i recall the manual recommending 18 psi..
what tire pressure are you using?
josh
2002 rubicon
jaffrey,nh
Old Sep 30, 2002 | 11:16 PM
bodine's Avatar
I'm thinking on the fender it says 6psi+or -2'but i could be wrong.
either way 6psi is what i run in my rubi
Old Oct 1, 2002 | 11:29 AM
RubiconRuff's Avatar
The recomended tire preasure is printed on the fender of the Rubicon. It is 3.6 psi. Thats what I run in mine and it gives a smooth ride with no bounce. With 18 psi it would look like a basketball bouncing down the trail. Even 6 psi is a bit much. I wouldn't run over 4 psi.
Old Oct 1, 2002 | 11:44 PM
swampdonkeykiller's Avatar
I would only run 5lbs in stock tires-less chance of a puncture as the tire will fold around stuff instead of hitting it hard. Anything above 10lbs printed on an atv tire is probably the pressure needed to seat the bead anyways and is not an operating pressure.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
