wheel nuts for ITP wheels
Old Oct 2, 2002 | 04:25 PM
Tomahawk350's Avatar
Anyone ever switch to ITP wheels? Or any wheels that have a flat face as opposed to the tapered hole on the factory rim?
What lug nut did you use? Did you add a washer?
thanks!
Old Oct 2, 2002 | 04:31 PM
buttfungus's Avatar
turn the stock lug nuts over and put the flat side against the aftermarket wheels. Works just fine.
chad400ex's Avatar
Yep, what he said...
Old Oct 2, 2002 | 04:49 PM
Team400EX's Avatar
I would still use a washer though. It rips the crap out of your rims otherwise.
~Team440ex
Old Oct 2, 2002 | 06:19 PM
YZGUY's Avatar
USE WASHERS FOR SURE!!!! If you don't use washers, the (hard steel) lug nut will smash the softer aluminum of the rim. Not only will it look bad, eventually you won't be able to get the rim off the stud.
Old Oct 4, 2002 | 02:47 PM
TechTip101's Avatar
I just learned the hard way that you must flip the lug nuts over if not they are a pain in the a$$ to get off.
Old Oct 4, 2002 | 03:11 PM
Yeller500HO's Avatar
I got my lugs from East Kentucky Motor Sports. They are real nice chrome lugs. I paid $25 for the whole set.
Old Oct 4, 2002 | 04:33 PM
ROE's Avatar
ROE
ITP WHEELS COME WITH LUG NUTS.DON'T REALLY KNOW WHAT SIZE NUT THEY ARE,BUT MY TACOMA PICK-UP HAVE THE SAME SIZE.
Old Oct 4, 2002 | 04:35 PM
TechTip101's Avatar
I believe they are 12mm. I must have gotten beat, cuz mine didn't come with the lugz.
Old Oct 4, 2002 | 04:37 PM
ROE's Avatar
ROE
CORRECTION,THE TACOMA LUG WRENCH WILL FIT THE NUTS THAT THEY FURNISHED WITH MY RIMS,PROBABLY NOT THE SAME LUG BOLT.
