What sprocket do I need with a 13 front
Old Oct 6, 2002 | 09:57 PM
rx7351w's Avatar
I have a 96 mojave and want to lower the gear ratio to climb better. It is 12/43 now. What size do I need with a 13 front sprocket and stock chain. I have a new chain that I'm ready to put on with the new gears.
Thanks
Chad
Old Oct 7, 2002 | 12:08 PM
mojaveaddict's Avatar
If you put on a 13, you will be going backwards from what you want.
A 13 will raise your gearing not lower it. You would need a 46 rear with it just to get back to stock. If you want to lower the gear you have to go smaller on the front and/or bigger on the rear. Try an 11 on the front with a stock rear. That will take you from a 3.58 to a 3.90 and it will climb easier but wind out pretty quick.
Old Oct 7, 2002 | 09:35 PM
rx7351w's Avatar
mojaveaddict
If I put an 11 on the front and leave the back stock will the stock 520 chain be too long? Top speed I'm not worried about. Where I ride 40mph is fast enough for me.
Thanks for you help
Chad
Old Oct 8, 2002 | 09:49 AM
It should do ok if you have plenty of adjustment left now. If not, it is really not that hard to take a link out. I have never ran an 11 tooth. They can sometimes cause problems because the chain has to make such a tight bend. keep an eye on things and check your chain adjustment often.
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
carolinabomb
Jul 26, 2015 08:40 AM
95wolv
Jul 17, 2015 08:13 PM
joeyupton
Jul 14, 2015 11:51 AM
