Sportsman 500
Old Mar 28, 2000 | 07:51 PM
nevermiss's Avatar
screen in front of radiator removable?
Old Mar 28, 2000 | 10:27 PM
Bill.Ciliberti's Avatar
Why would you ever concider removing that screen?It has saved my radiator from repair probably a hundred or more times.It stops twigs,branches,and other things that would otherwise go into the radiator.Better think twice before removing it.===BILL
If you want to come in second ''FOLLOW ME''
Old Mar 29, 2000 | 06:37 AM
nevermiss's Avatar
Leaves and stuf caught between it and the rad. One more thing awd light on all the time in foward gear is this normal or should it come on only when the fronts engage?
Old Mar 29, 2000 | 07:50 AM
bad2bone's Avatar
My AWD light stays on when the AWD switch is in the on position, whether or not the front wheels are engaged. I would assume that is the way it is was designed to work.
I also would not remove the screen, you need all the protection you can get for the radiator.
Old Mar 29, 2000 | 08:54 AM
markshop's Avatar
I didnt even know there was an AWD light. Is it the one all the way to the right on the pod. If so mine has never worked.
Old Mar 29, 2000 | 09:20 AM
bad2bone's Avatar
Nope the AWD light is located on the AWD switch. If the switch is in the off position, the light is under the switch. It is exposed only when the switch is in the on position.
As far as the rightmost light on the pod, mine is blank too. I have 2 2000 SP500s and it's blank on both.
Old Mar 29, 2000 | 10:36 AM
floodrunner's Avatar
“If (when) the switch is in the off position, the light is under the switch,” how do you know the light turns off when the switch is off?? (hehehe) Sorry, just a little refrigerator humor ;}
Old Mar 29, 2000 | 11:02 AM
bad2bone's Avatar
Flood,
Just couldn't pass it up could you! Can't say as I blame you!
Bad2Bone
2 '00 SP500s
Old Mar 29, 2000 | 12:19 PM
markshop's Avatar
bad2bone Thanks for the info.
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
