250r AXLE!!!
Old Oct 10, 2002 | 01:01 AM
86trx250rhonda's Avatar
Default 250r AXLE!!!
I just bought a durablue emlimanator and is trying to put it on and i can't get the stock axle nut off. How do you get it off with out busting the brake hub. I have tried for hours trying to get the stupdd thing off (using the manual) and what people have told me. I think that it is just froze on there and will not come off please help me . Give some ideas to get it off with out busting th brake hub i'm already buying a lock axle nut. Thanks
Old Oct 10, 2002 | 01:59 AM
tricky1's Avatar
Since your replacing the axle. i used a big wrench big enough to stand on and took a torch to heat it up and had some one stand on the wrench it finally came loose. i have a 86 also i dont think the ever had it apart since it was assembald.
Old Oct 10, 2002 | 04:14 AM
elsancho's Avatar
remember that it pushes against teh retaining ring so if you want to loosen it you need to turn it clockwise
Old Oct 10, 2002 | 01:43 PM
MX400EX2's Avatar
Yes, they are reverse threaded.
Old Oct 10, 2002 | 02:27 PM
evhwg's Avatar
yes reversed threaded and i had to jump on a big adjustable wrench to get mine off...
Old Oct 11, 2002 | 12:47 AM
I have tried a 18" wrench on the nut and had a 3' cheater bar with 2 people helping me and it still will not budge. I'm probley just going to cut very easily through the inside nut with a dremel tool and try not to hit my brake hub. I'm going to buy a new axle nut should i just spend the $50 and get the durable one or save and buy the brake hub with no-fad axle nut?
Thanks
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
1000gade
Sep 9, 2015 04:41 PM
