rear foot brake, why can't I use it?
Old Mar 29, 2000 | 07:22 AM
BLH's Avatar
BLH
I have been told not to use the foot brake. Why? what could it hurt? I ride were there are some steep hills, useing the rear brake only would make going down feel safer.
Bruce L. Hall
99 Sport 400
Old Mar 29, 2000 | 09:10 AM
A400L's Avatar
It's only designed to be an auxilary brake. It does'nt hurt to use it occasionally.
Mine never worked, when I split my brakes for independant front/rear, I removed the entire foot system and threw it away.
Old Mar 29, 2000 | 10:12 AM
BLH's Avatar
BLH
I've been wanting to get the spit brake kit. Did you get the additional mater cylinder, did you use the orig? I herd that if you use the one one the quad now, that your rear brakes will feel mushy. Bottom line would you buy them again? Do you recommend them? I'm planing on getting a RCR kit in April, the brake kit this summer, if its worth it. thanks
Bruce L. Hall
99 Sport 400
Old Mar 29, 2000 | 10:23 AM
Tim1's Avatar
I Disconected my rears brake because I kept standing on it without knowing it while riding and wore the back pads off.I find the one lever with it's 60% 40% front, back power split works fine for me.
Old Mar 29, 2000 | 03:21 PM
Thor's Avatar
You should not have any problems using it.
Most of the advice not to use the rear brake refers to the older *non concentric drive* machines where the brake when used with the foot was completely mechanical and quickly went out of adjustment.
Shainasmash
May 8, 2017 06:38 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Sandman2.0
Jul 21, 2015 09:03 AM
timster911
Jul 13, 2015 01:57 PM
