need help, scooby-anybody
Old Oct 13, 2002 | 08:20 PM
dsmike's Avatar
Default need help, scooby-anybody
when you split the cases what side should you pull so everything doesn't fall out? does anyone have a manaul that shows what order the tranny gears go?
Old Oct 13, 2002 | 09:08 PM
ScoobyDFW's Avatar
Jeff might be able to help with the tranny since he has removed all the gears.
You have to make yourself an engine stand! The case should not be split without the motor being secured and level, with it's RIGHT side facing down (magneto side). The crank is very heavy and it can damage the bearings if allowed to tilt with cases loose/split. I made one out of wood. I bought some long bolts and some spacers to bolt the engine to the stand through the engine mounts.
You should have a service manual and parts catalog to refer to. There are shims on most shafts, both sides in some cases. You need to be sure you put everything back together exactly as it was!
Old Oct 15, 2002 | 12:11 AM
dsmike's Avatar
wheni was taking the flywheel off the puller broke. is there any other way to get the flywheel off? do i need to buy anohter puller?
its not looking very good for me attending aledo.
Old Oct 15, 2002 | 12:27 AM
ScoobyDFW's Avatar
People have broke those pullers on several occassions. I think MarkyNark or modquadracing had a heavier duty one made. I think the BMW F650GS part number for the puller is 125510. Heating the hub to 176 degrees was mentioned in BMW manual before pulling.
Old Oct 15, 2002 | 12:33 AM
dsmike's Avatar
thanks, i was think of welding another nut to the puller and putting a new bolt though to pull it off. you think that might work? i will not have time to wait on parts if 'm going to race this weekend.
Old Oct 15, 2002 | 11:19 AM
biggerisbetter's Avatar
Steve,
Good luck with the tranny, I hope you get it going by this weekend man. Iknow I am 4 hours away, but if their is something I can do to help, just let me know.
Biggerisbetter.
Old Oct 15, 2002 | 11:41 AM
jeffnrivercity's Avatar
If you apply a small amount heat(with a torch)around the flywheel..it will pop right off (with the puller on it of course)
Jeff
Old Oct 16, 2002 | 12:22 AM
14mins's Avatar
Hey Jeff- how about a "business trip" to Aledo on october 19th. No need to think about it just show up. You and Randy, Scooby, Dsmike, Dollarbills and Raptorboy 673 all race for the glory. I bet we could even get people to pay to watch those.
Old Oct 16, 2002 | 11:33 AM
14mins,
Thats a great idea....but I will going to Sand Mountain this weekend....
Take lots of pics..so it will feel like I was there[img]i/expressions/face-icon-small-happy.gif[/img]
Thanks for the invite..
Jeff
Old Oct 16, 2002 | 11:39 AM
14mins's Avatar
will do captain. Just thought i would try[img]i/expressions/face-icon-small-happy.gif[/img]
