Fan over ride switch on my Rubicon..
Old Oct 19, 2002 | 11:57 PM
MobileMan's Avatar
Default Fan over ride switch on my Rubicon..
...Hey I noticed my recently purchased 01 Rubicon has a fan, I own other street-bikes that also have fans and I always install a "manual" switch to turn on the fan before it needs to come on, I plan to install a temp gauge as well, my question is "Where is the best place to "tap" in to the fan? the fanswitch? the wire? has anyone else done this? if so what worked best?
Thank you
MM
Old Oct 20, 2002 | 06:20 AM
swampdonkeykiller's Avatar
If you do a search for Fan switches or something along those lines, you should bring up a few old posts that discuss this. One guy has directions on how he did it. I would suggest putting a relay in somewhere so you don't burn switches out as the fan does draw a few amps.
Old Oct 21, 2002 | 12:27 AM
JRM's Avatar
JRM
tex mudder has done it over at www.ansley.net
Old Oct 21, 2002 | 04:54 AM
Yeah that's where I saw it. Excellent directions.
Old Oct 21, 2002 | 10:14 AM
action450s's Avatar
Make sure to tightly twist the wire connection and solder it. Also should use heat shrink tubing or at least good electrical tape such as 3M, not the crappy $.50 drug store variety.
tiresharkdbb
Sep 3, 2017 02:06 AM
txkevin
Sep 21, 2015 02:02 PM
BEEFKING69
Jun 17, 2015 12:38 AM
wildbill59
Jun 9, 2015 02:28 AM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
