using K&N cleaner and oil on stock air filter
Old Oct 20, 2002 | 09:36 PM
grademan's Avatar
Default using K&N cleaner and oil on stock air filter
Is it ok to use K&N air filter cleaner and oil on a stock 400ex air filter?
Old Oct 20, 2002 | 11:35 PM
SparkyEX's Avatar
no
Old Oct 20, 2002 | 11:47 PM
swampdonkeykiller's Avatar
Why not? Aside from that, seeing as you already have the oil and cleaner, pitch the old filter in a box and just buy a K&N. Then when you sell it, and buy a new one, put the old filter back on before you sell it and put the K&N on the new one.
Old Oct 21, 2002 | 12:28 AM
grademan's Avatar
OK, But why not?
Old Oct 21, 2002 | 09:22 AM
95wolv's Avatar
The K&N oil is set up for cotton or gauze type media,it is thinner,and not tacky like foam oil. the gauze is finer,so it needs an oil to flow into all the fibers evenly. The foam type oil is thicker,that is why they recommend you work it into the foam for good coverage. Touch a foam filter after it is oiled-see all the little stringers come with your finger? that is to catch dirt as it bumps into the open cells in the foam. The thinner K& N oil will cover a foam filter, but without the 'sticky', a lot more dirt will get by. Hope this explains it for you.
Old Oct 21, 2002 | 10:59 AM
grademan's Avatar
Thanks 95wolv.
Ronk407NY
Feb 13, 2016 11:05 AM
house1
Aug 9, 2015 10:49 PM
GregM
Jul 29, 2015 09:41 PM
Aitch
Jul 21, 2015 09:40 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
