Cold Weather Jetting
Old Oct 21, 2002 | 09:10 AM
monteSS's Avatar
Default Cold Weather Jetting
Do you drop a jet size or do you raise it a jet size since cold air is denser?
This is another reason I want to install Dial a jetset it in the middle and jet for that then you can up or down it for altitude and weather. Mayby I'll ask for one from Santa incase the Ignition box isn't ready yet. Any news or updates on that and the tranny filter????
Old Oct 21, 2002 | 10:52 AM
Surveyor's Avatar
Monte,
per a Mikuni Carb tuning guide (about 3 bux from Dennis Kirk) if the temperature CHANGE (note this means that if it is spot on at 80 degrees, and you ride it at 50 degrees the temp change is -30 degrees...)
anyhow..if the temperature change is about 25 degrees colder, you could go richer by a size
Old Oct 21, 2002 | 11:41 AM
monteSS's Avatar
Thanks I will probably have to go a size larger around here it gets below 30 usually in the winter exept the past two
Old Oct 22, 2002 | 12:38 AM
alltoys's Avatar
MonteSS
I wouldn't worry about rejetting unless you are going into ice raceing. I run mine in -45 with no adverse affects except for colder nether regions. Keep your same jetting its not that big a deal.
Old Oct 22, 2002 | 06:36 AM
monteSS's Avatar
Thanks I guess I will just ahve to wait. I just rather be rich than lean.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
