p650 air filter
Old Oct 23, 2002 | 11:07 PM
packardbell15's Avatar
Default p650 air filter
what can i use to clean the air filter on it. i usually just use soap but it doesnt do good. what should i use? i heard to use gas and then not to use gas. after i clean it i always use belray foam filter oil.
Old Oct 23, 2002 | 11:13 PM
nyroc's Avatar
Use the foam filter cleaner that you find at the motorcycle shop. Belray probably makes it too.
Old Oct 29, 2002 | 05:47 AM
scootdog's Avatar
use nitromethane, it cleans anything.....
Old Oct 29, 2002 | 08:00 AM
trx450's Avatar
scootdog--- I am surprised you didn't suggest C-4 explosive! LOL
Seriously, I use kerosene. I dip it, lightly wring out the K-1, blow out the rest with CAREFUL use of an air gun and let dry overnite. Oil it, and ride.
Old Oct 29, 2002 | 09:14 AM
cammoman's Avatar
The best way to clean foam filters is parts solvent, you can get it at most auto parts stores. It cost's about $3-$4 a gallon but it will last a long time. Just put it in a bucket with a lid so you can store it. If you want to get real creative make about a 3" mesh basket the size of the bottom of the bucket and put it in upside down so when you wash the filter all the dirt settles to the bottom. This is the easiest way to clean a filter and it is as clean as new. I used this method for three years when I raced motocross, and I cleaned my filters (3 of them) at least 4 times a week. That means the solvent would last at least a year or longer with your Prairie. I've only had my 650 for 6 months and switched to the K&N filter, I don't think it's a good idea to use the solvent on the K&N. They make a special cleaner for that one. Try the solvent you won't believe how good it works!
Old Oct 29, 2002 | 11:54 AM
trailburner's Avatar
nyroc?
you have mentioned that the air filter box has changed in the 03 models. will this allow an 02 k&n filter to fit better? Do you know? If not, I can't find a k&n air filter for the 03 p650.
Old Oct 29, 2002 | 07:25 PM
DustinMinnesota's Avatar
The 02 and 03 filters are totally different. Teh 02 filter was flat where the 03 changed airhorns and mounted the filter like an automotive type sort of trioval down in the box. However I imagine you could put an 02 filter in the box but you would have to remove the retaining cage for the 03 filter.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
