tire's?
Old Oct 27, 2002 | 08:12 PM
SportTrax250ex's Avatar
Default tire's?
sorry newbie question. i just got a 2003 TRX250ex and its all stock. its my first Quad so i'm new to this. i was thinking about getting some new rear tires that are good to run when its muddy and when its dry. what are some good one's to get? [img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 27, 2002 | 08:41 PM
01redrecon's Avatar
Default tire's?
A good tire that does well in mud and on the trails is the surtrac tire or the spidertrac's. My bearclaws are good but just a little agressive at times. I have to be careful where I do a donut or I could be laying on my side, but they do slide around on the trails good and do good in the mud.
Old Oct 27, 2002 | 10:08 PM
Default tire's?
thank. i have stock 22's on the rear now. will 20's give it more bottom end? being i can't change sprockets do to being shaft drive.
Old Oct 28, 2002 | 02:41 AM
nick01's Avatar
Default tire's?
The 20's will give you more bottom end but you will wind out at a slower speed in high gear, have less ground clearance, drag the bottom over more rocks and obstacles,a greater chance of getting high centered because the frame will be lower, and get stuck easy in the mud. If you do not see any of the things that I have mentioned a problem then go ahead and get smaller tires.
Old Oct 29, 2002 | 06:35 PM
redrider101's Avatar
Default tire's?
when i had my 250ex a year ago, i put maxxis raz r 4 ply tires on it and i performed well in both wet and dry conditions, and they are also alot lighter than most agressive tire designs (spider trak, sur-trak) good luck towards you purchase
Old Oct 29, 2002 | 09:11 PM
Default tire's?
thanks guys for the info. where i ride at i don't have to worry about bottoming out on rocks and logs, just the mud holes. theres just alot of hills to go up and down not real steep though.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
