wiseco piston
Old Oct 27, 2002 | 10:06 PM
TeamEx's Avatar
Default wiseco piston
to have a wiseco piston does the motor need to be bored
thanx
Old Oct 27, 2002 | 11:10 PM
reconbasher's Avatar
not if you get the factory bore size and the use that size to order your wiesco
Old Oct 28, 2002 | 08:56 AM
truckracer's Avatar
It all has to do with the clearance between the piston and the cylinder. And how round or out of round the cylinder is.
The Weisco piston is going to be forged, forged pistons normally need more clearance than the stock pistons do. This can work for you if your cylinder is stock bore but worn evenly (still round). Then you can install the stock bore forged piston and be okay. If your cylinder is not worn and you install the forged piston it may be too tight when everything heats up and and it will gall or seize.
Bottom line - mic your cylinder, most machine shops will do this for free, then decide from there. Find the specs on the piston for your engine (Weisco prints it right on the box). [img]i/expressions/face-icon-small-smile.gif[/img]
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
