**i need a larger mojave gas tank**
Old Oct 28, 2002 | 06:15 PM
MOJAVE02's Avatar
Default **i need a larger mojave gas tank**
i need a gas tank ranging from 3-5 gallons for my mojave. does anyone make one for it? and if not what can i use that will fit on this? i really need help. what are the racers running for oversized tanks? lurch what kind of tank are you running?
Old Oct 28, 2002 | 06:55 PM
albaBANSHE's Avatar
you might be able to fit a 250r 5 gal tank between the side of the fenders of the tank ?
Old Oct 28, 2002 | 06:57 PM
MOJAVE02's Avatar
does it have the same bolt holes? and do you think it will work?
Old Oct 28, 2002 | 11:46 PM
albaBANSHE's Avatar
i was thinking cutting the top plastic off where the top of the tank is and sliding a 3-5 gal in the slot and zip tie,or bolt it in that is what my uncle did
Old Oct 29, 2002 | 08:08 AM
MOJAVE02's Avatar
did it seem to work okay just sip tying it down?
Old Oct 29, 2002 | 07:30 PM
albaBANSHE's Avatar
yea ok i guess? but i am sur you could find other ways to mount it
Old Oct 30, 2002 | 01:38 AM
Chris142's Avatar
The problem with the Mo tanks is that even when your "out of gas" there is nearly a gallon left in the tank that cant be used due to a poor design.There are no aftermarket tanks made for it.I carry a 2-liter soda bottle full of gas,mounted between the 2 frame tubes on the front.
My friends call it "the bomb"! It has got us out of several out of gas jams.
toonces
Sep 5, 2015 01:14 PM
antiguogrumete
Sep 5, 2015 03:41 AM
2007 Grizzley 450
Aug 13, 2015 06:33 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
