Recon Valve Adjustment
Old Oct 28, 2002 | 08:46 PM
rideredinvt's Avatar
Default Recon Valve Adjustment
Is there an easier way to adjust the valves on a 03 recon es? The service manual talks about taking everthing off on the front end. Has anyone tried any other way. I can't believe my dealer does the first inspection for only $60.00 and he has to go to all that trouble to adjust the valves. There must be a flatrate way to do this and only charge 60.00. Any suggestions or insights would be great. Also where do you purchase the valve adjustment tool. Is it a Honda dealer only tool?
Thanks
Old Oct 29, 2002 | 10:44 AM
moto93's Avatar
You have to take everything off in order to get to the valve caps. It's a pain the butt I know but it has to be done. After a few times of doing it it's not really to bad though. You can use a small pair of pliers instead of buying a special tool.
Hope this helps,
Old Oct 30, 2002 | 08:51 AM
gergb's Avatar
rideredinvt, To access the valves you do not need to remove the front racks or fenders! Leave them on! Just remove the side covers and gas tank(it is a tight fit, but by a little wiggling and fussin' you CAN get it out). Use a feeler gage to set the valves. You can buy it at any auto parts store. The feeler gage should be a snug fit,not real tight.
Old Oct 30, 2002 | 11:02 AM
moto93's Avatar
gergb,
Don't forget the new Recons (2001 on up) have a diferent style head on them, like a a 250EX. Instead of one cover over the valves there are two, one towards the front, the other toward the back.
Old Oct 30, 2002 | 03:48 PM
Peltrax's Avatar
How often should you adjust your valves on a recon?
Old Oct 31, 2002 | 09:08 AM
gergb's Avatar
moto93, I just looked at a microfishe at a 2001 Recon and it only has one valve cover. Maybe 2002 and up are a little different, but, you should still be able to access the entire top of the cylinder head as none of it is under the front rack or front fenders!
Peltrax, I believe the owners manual suggest the first adjustment at 20 hours, and every 100 hours after that. I just check mine every year before the first big ride. (usually no adjustment needed)
Old Oct 31, 2002 | 10:51 AM
moto93's Avatar
You are right Sir. The 2002 models are the ones that changed. My bad.
donintennessee
Jan 8, 2021 12:40 PM
Hankey Pankey
May 1, 2018 01:33 PM
Hunter100us
Oct 7, 2015 11:46 PM
Hondamx751
Aug 13, 2015 01:06 AM
MNatv89
Jul 7, 2015 11:36 AM
