CV Shaft Kit for 450s
Old Oct 29, 2002 | 04:54 PM
KajunATVer's Avatar
Default CV Shaft Kit for 450s
Does anyone know where I can get a CV shaft kit at a reasonable price for a 1999 Foreman 450s. I checked Honda of Troy and they want $247.00 PER SIDE!!!!!! Any help is appreciated.
Old Oct 30, 2002 | 12:59 AM
scosho's Avatar
Ouch! Did you rip a boot or have another mechanical failure?
Old Oct 30, 2002 | 09:02 AM
KajunATVer's Avatar
I don't know what happened but the front end clicks and pops, especially when I turn. Other than the noise, it still works fine though.
Old Oct 30, 2002 | 03:47 PM
450HondaForemanS's Avatar
just saw one on ebay an hour ago. forgot the price but should be cheaper
Old Oct 30, 2002 | 06:11 PM
trailboss450's Avatar
25 Year Member
One other thing you should know about is that if you have changed the front differential gear lube and put in other than original equipment fluid it will chatter on turns. You need to put in some limited slip additive. The GM stuff works good and will stop chatter in the front end. Also the parts to repair a cv-joint are available separately. No need to replace the whole thing unless its broke.
Old Oct 30, 2002 | 06:30 PM
KajunATVer's Avatar
Thanks for the replies. I'll check on the individual parts after I tear into it. Oh yeah, I already have the GM diff. fl. addative.
Old Oct 31, 2002 | 12:41 AM
scosho's Avatar
I was scanning ads in DirtWheels, saw aftermarket inboard cv joints "better than OEM" advertised by some parts house. What you describe sounds like CV, can you isolate it to just one? Maybe you don't need a shaft with cv at each end.
95wolv
Sep 27, 2024 12:00 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
shimanok2
Jan 29, 2016 07:37 PM
NewGuy2481
Oct 6, 2015 05:54 AM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
