650 grinding noise
Old Nov 1, 2002 | 11:49 AM
th41004's Avatar
Default 650 grinding noise
Ive had my prairie for about a year now with around 1100 miles. It is makiing a clicking noise coming from the right side. It is not in the cvt cover it seems to be coming from underneith. You can actually feel a pop in the floorboard when it happens. The wierd thing is I can jack all four wheels off the ground and start it up, turn it and everything without a sound. It seems to do it worse when turning right, it does it in 2 and 4 wheel drive. Its not coming from the cv joints that is the first thing I checked. If anyone has any ideas please let me hear them. I am stumped.
Old Nov 1, 2002 | 12:03 PM
monteSS's Avatar
Did you check your tie rod ends, lower ball joints, any bolts in the front, strut bolts. Does it happen when you are sitting still and turn the wheel on the ground, moving?
Old Nov 1, 2002 | 12:13 PM
th41004's Avatar
Yes I checked all that. It only does it while riding, usually when turning right. The sound is coming more from underneith the engine than in the front end.
Old Nov 1, 2002 | 12:47 PM
monteSS's Avatar
Does it do it while going slow where there is limited suspwnsion movement or when you are going fast and having more suspension movement?
Old Nov 1, 2002 | 12:59 PM
th41004's Avatar
It seems to do it both fast and slow but you can really notice it if you run the right front tire up on like a bank or something . I have even jacked the whole thing up ,then compressed the right front and still no noise. Its driving me nuts.
Old Nov 1, 2002 | 01:30 PM
monteSS's Avatar
Did you check for wear on your lower contron arm bushings and your lower ball joint to check your ball joint you need to jack it up by the a-arm and grab the top and bottom and try band and move the wheel.those parts would be something that you would feel in the foor boards. Since they are bolted right there.
Old Nov 1, 2002 | 02:10 PM
th41004's Avatar
Yes I tried all that when I jacked up the right front everything is tight with no play at all.
Old Nov 1, 2002 | 02:17 PM
NovaKaw650's Avatar
I saw one P650 that had a swingarm bearing. It made a clicking noise and you could feel it in the floorboard.
Old Nov 1, 2002 | 03:05 PM
monteSS's Avatar
NovaKaw650
He may be on to something there to. It doesn't soound like it is in the front if you tried every thing. Good luck let us know when you find out.
Old Nov 1, 2002 | 08:30 PM
pcpacker's Avatar
I have had a similar click with mine since day one. I haven;'t felt it pop however
