300EX motor question
Old Nov 1, 2002 | 08:03 PM
motoxpress's Avatar
Default 300EX motor question
I have an open hole on the top of the motor. Check out the pict:
http://www.motoxpress.com/300ex/mystery_hole1.jpg
What is it?
MX
Old Nov 1, 2002 | 08:11 PM
mascman's Avatar
Is the hole threaded? My Warrior has a bolt in the head to verify that you are getting oil pressure. May be what that is for. Have you been running it like that?
Old Nov 1, 2002 | 08:18 PM
RideRed420's Avatar
I looked at my 300,
it is like a blow off valve(like on a car)
from what i seen a hose comes off there and goes through
a tube and then into the intake(next to the airbox).
Old Nov 1, 2002 | 08:54 PM
mascman's Avatar
So it must be your crankcase breather. Route the hose into the airbox or put a breather on it.
Old Nov 1, 2002 | 08:56 PM
RideRed420's Avatar
yeah the hose ran into a little clear box
than into the intake
Old Nov 1, 2002 | 11:13 PM
Need4Speed's Avatar
Yep, it runs all the way though your valve cover through your cylinder and into your crank. It's just a breather in case your crank creates too much pressure. If you dont have it you could be going through gaskets pretty quick. It's an L shaped type of deal. On the 250X's the open end faces the front of the quad and a tube runs from it into the frame. The tube might be on the frame on the EX's but I dont know. Otherwise just run it to your air box.
Old Nov 1, 2002 | 11:24 PM
RideRed420's Avatar
on the 300ex,
it bends to the back of the quad.
ronnierhino06
Nov 9, 2015 12:56 PM
Asaran
Oct 8, 2015 11:14 AM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
