400ex stock head pipe glows in dark...
Old Nov 5, 2002 | 05:47 PM
love250x's Avatar
Default 400ex stock head pipe glows in dark...
I was warming up my 400ex and when i reached down to turn off the choke i noticed the header pipes glowing red, not just a slight tint, but really red. Is this normal?
Old Nov 5, 2002 | 05:57 PM
300exRiderJay's Avatar
were you in the dark or were you in conditions with lighting? Either way, i am stumped on what is happening.
Old Nov 5, 2002 | 06:02 PM
YZGUY's Avatar
I have never seen this, but I would imagine if you are sitting for a while and there is no air passing over the engine, the pipe could get red hot pretty fast. Does your bike have stock jetting?? Stock jetting is on the lean side (to meet emissions), which can make a motor run hot. On the other hand, if it happens while you are riding, I would check to be sure you are not running extremely lean.
Old Nov 5, 2002 | 06:13 PM
RacinJason's Avatar
The materials in the stock pipe pass heat extreemly well...this is normal for many of the new four-strokes with stainless head pipes...seen it on anything from DS, Raptor, CRF450, take a plug reading to assure that you arn't to lean at an idle.
braaap!
love250x's Avatar
I was sitting still in a dark shed. Not completely dark though. When I pulled out in the driveway I couldnt see it anymore. Jetting is stock. It only gets red when im reving up, not when its idleing.
Old Nov 5, 2002 | 06:46 PM
fuddrucker's Avatar
Perfectly normal.
Mine does the same thing except it is a 300 with a DG pipe and header. Only glows if I am reving it up in nuetral and keeping it there for like 20 seconds.
Old Nov 5, 2002 | 08:20 PM
I guess i will try this on my 300ex tommorow. It is completley stock but it might still happen. I'll update you on what happens.
Old Nov 5, 2002 | 11:49 PM
chad400ex's Avatar
The stock head pipe is single-walled, and will get hot and glow when left to idle. Mine did the same thing when I bought it new. After fattening up the jetting, it never happened again. A motor that is running lean will run hot.....enough said.
Old Nov 6, 2002 | 02:21 PM
RideRed420's Avatar
it should be normal........
Asaran
Oct 8, 2015 11:14 AM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
metal249
Jul 28, 2015 09:35 AM
95wolv
Jul 21, 2015 12:25 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
