KLR 650 motor in MOJAVE
Old Nov 5, 2002 | 08:54 PM
mojavekid13's Avatar
Default KLR 650 motor in MOJAVE
I just wanted to knwo if u guys though it was possable to put a KLR 650 motor in a mojave frame!?
Old Nov 5, 2002 | 11:10 PM
Lurch's Avatar
The motor is 2" too tall to fit in the cradle. Believe me....I have already thought of this ride.
Old Nov 5, 2002 | 11:11 PM
albaBANSHE's Avatar
at one time i had a 91' kx 250 motor in a 1987 mojave you could prob fit it but you have to cut the current mount and weld them to the 650's needs,the sprokets have to be aligned too! now the 87 has the stock motor back in it but wanting to put a tri-z dead motor i have in it all it will need is rings and a gasket set!
Old Nov 6, 2002 | 07:49 PM
FuelandFire's Avatar
A Ninja 500R motor will fit in there. Kind of heavy though, but it puts out about 60HP stock!
Old Nov 7, 2002 | 07:39 PM
01TRX300EX's Avatar
I would personally try and put a KLX300 motor in there, its kind of an updated Mojave motor I believe, but thats just me.
Old Nov 7, 2002 | 08:10 PM
think it would work?
Old Nov 8, 2002 | 06:46 PM
01TRX300EX's Avatar
If you are asking if the KLX300 motor will fit, I would say yes, you would probably have to make new brackets, but height wise it should be fine.
Old Nov 8, 2002 | 07:55 PM
I bet the 650 Engine would fit in a Lokata Frame because it is an inch or so lower on the lower frame rails than the Mojave. A new Lakota is around 600 bills but the rest of the Mojave stuff should bolt up. If anyone has a 650, I can measure my wifes Lakota frame for a fit.
Old Nov 8, 2002 | 08:54 PM
killerkx327's Avatar
mijave addict. i wouldn't try the klr motor but the 95-97 klx 650 motor will fit.it's a very nice liquid cooled 650 motor and alot more compact then a the klr motor.
Old Nov 8, 2002 | 11:17 PM
I may have to try and find me one of those motors!
