i have no idea what i am doing
Old Nov 7, 2002 | 08:23 PM
Uglyman32's Avatar
Default i have no idea what i am doing
ok this is my first time jetting. i have read all of butfungus's charts and i have done all of it but its not working. i have full big gun exaust, ronwoods cdi,carb filter. i just put in the 195 jet turn the screw in and whent back out to 3 turns. revs fine but when i get on and let the clutch out it dies on me and sometimes get a bad sound when it does from the engine. i have been di**ing around with this all day and could realy use your help. than you
Old Nov 7, 2002 | 08:24 PM
Uglyman32's Avatar
my elevation is 750ft
Old Nov 7, 2002 | 08:41 PM
Uglyman32's Avatar
the needle is 3rd from top. now messing with screw and have some power now but i cant get about 4g rpm
Old Nov 7, 2002 | 08:43 PM
buttfungus's Avatar
If your using mikuni main jets, then put the e-clip on the very bottom notch! A mikuni 195 main may be a little rich. Try a 185/180 and see.
Old Nov 7, 2002 | 08:50 PM
Uglyman32's Avatar
they had 165 and then 190 and so i also got the 190
Old Nov 7, 2002 | 11:54 PM
BlackHawk's Avatar
165 Mikuni is stock, if you went from a 165 to a 190, that is a huge jump. I had a 190 Dynojet which is approximatly a 178 mikuni, and that was too rich for my ATV at 3000' feet. I just changed to a 185 Dynojet and will see how it runs. Your 190 mikuni is closer to a 203 dynojet. You should try getting the 170, 175, 180, 185 jets. Since you've got the 190 and it stumbles a lot, try the 185 with a brand new pair of plugs and see what happens. If it goes OK, run it for three hours then check the plugs, if they are black go down to the 180 and run it for another three hours then check. The stock position for the screw is 2.5 turns out, however when I went by someone else's instructions on how to adjust it, mine seemed to want to be at three turns, I've also heard this screw has only a little to do with how it runs overall and isn't going to make a huge difference. If you end up spending a lot of cash on jets, you might consider the dynojet kit, since it has everything from a 160 up to a 200 in it (Dynojet numbered, of course.)
Old Nov 8, 2002 | 12:12 PM
PDXDS650's Avatar
I have all the Mikuni jets between 165 and 180 (165, 167.5, 170, 172.5, 175,..)that I no longer need as I just installed my Dynojet kit. let me know if you are interested in them.
Old Nov 8, 2002 | 12:24 PM
KenDS's Avatar
Buttfungus and Blackhawk are right on. You are waaaay too rich. You will probably end up with a 170 or 175 Mikuni. We are at the same elevation and that is what I used successfully until I bought the Dynojet kit. I highly recommend the Dynojet or K&N kits for the first time jetter. Use the set-up for below 3000 ft in the instructions and you should be happy with the performance.
Old Nov 8, 2002 | 05:24 PM
AZDUNNER's Avatar
Your way too rich. - I run the same setup as you.
Big Gun Full Race
R/W CDI
K&N Carb Mount
I live in Phoenix AZ. Elev. Approx 1200 ft.
Big Gun recommendes a 175 Main Jet and that's what I use. Never had a problem.
Try a 175 Mikuni - I wager that's your problem.
Old Nov 8, 2002 | 08:56 PM
Uglyman32's Avatar
thanks guys i will do that this weekend. btw, while tunning and testing all day going back and forth with butfungus , i woke up this morning and found that i forgot to put back the big spring after moving the clip on the needle. DUUUHHHH. well i put it in and it still cuts out about 6rpm so i will be getting the 175 like u guys suggest.
PS. what rpm should i be able to hit with the ron woods cdi?
