Camo prairie 360
Old Nov 8, 2002 | 09:30 PM
4wheelr220's Avatar
Default Camo prairie 360
Ok, I have 3 questions.
1. How easy should the camo covering chip off, almost all of it is gone from the under side of the fenders and a little from the edges.
2. How stiff should the rear shock be I have only had it a short time and I can push on the rear racks after a short easy ride and bottom the shock out, its already on its hardest setting too.
3. Also, should the belt squeak whenever I take off, its almost always a short chirp when I take off in high, an even when im in low and ease up to a log or other short ledge the belt squeaks.
Old Nov 8, 2002 | 10:26 PM
nyroc's Avatar
1. ? I dunno
2. Nope, it should not be that soft at the hardest setting.
3. No, it should not chirp. It needs a new belt, adjusted tighter, and a stiffer driven spring installed. I know that the 360 cvt is nearly the same as the 650, and that the general rules apply.
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
PrairieDog126
Sep 12, 2015 05:23 PM
DFWSRT8
Aug 20, 2015 09:24 AM
toonces
Jul 11, 2015 12:01 PM
