Trinity turbo head mod
Old Nov 12, 2002 | 02:14 PM
sam250's Avatar
Default Trinity turbo head mod
Anybody tried the turbo head mod that trinity racing does on their 250 Racer?
Old Nov 12, 2002 | 02:47 PM
calquadracer's Avatar
I have it on mine, seam to work good for the money. I had the engine built by Trinity at the same time so hard to tell if it will make a difference by its self but If Harry say's it will help trust him. Harry knows his stuff when it comes to mods.
I had to motor built for TT racing and it Screams!!!
Old Nov 13, 2002 | 12:34 AM
WP's Avatar
WP
It helps swirl the air and fuel to mix and burn better.
Old Nov 13, 2002 | 01:46 AM
kevlt250r's Avatar
WHAT ALL DID YOU GET FROM TRINITY? I BOUGHT A 38MM CARB. I HAVE A BOYESEN ON IT RIGHT NOW TO AND I AM HAVING A FIT GETTING IT TO MOUNT TO MY AIR BOX BOOT. I SEEN THAT TRINITY USES V FORCE. I WAS WANTINNG TO TAKE OFF MY AIR BOX AND MOUNT JUST A FILTER. THE SHOCK IS IN THE WAY. DO YOU HAVE ANY IDEAS?
Old Nov 13, 2002 | 02:39 AM
fast1's Avatar
i was told by a sells person at trinity, that it's worth about 1 hp?
Old Nov 13, 2002 | 05:08 AM
elsancho's Avatar
on teh honda r's a cr250 boot is used when using an aftermarket reed( w/ reed spacer). the cr250 boot changes the angle of teh carb and allows it to pass to the side of teh shock.. it isnt perfect, it still requires a little muscle to fit it in, but it helps. also remember that when you use a reed spacer it in effect pushed back your whole intake assembly so fittiing it into your stock airbox will be very difficult. ESR makes an airbox eliminator kit. you may want to look into it
Old Nov 13, 2002 | 07:07 PM
dinksdairy's Avatar
I have a 44mm on my zilla, i use no airbox and have a large peace of hose and a 45 degree pvc elbow with a KN on it. Works good, keeps it off of my shock. Soon I am gonna fabricate a box that sits far back and haves a pipe or hose that makes its way to the carb. Just incase it ever sees mud.
Old Nov 16, 2002 | 08:40 PM
Qracer31's Avatar
kev
i used a intake boot from a 89 lt500 it angles off to the right, straight to the carb then to a reducer, then a 250r
k&n filter. no problems yet
ReconBayou
Oct 31, 2022 05:37 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Sep 23, 2015 06:23 AM
