Belt Deflection Measurement
Old Nov 18, 2002 | 12:50 PM
rty's Avatar
rty
Default Belt Deflection Measurement
I put in the black secondary spring on my '02 P650 (only 29 miles, 4 hrs) and I have a question.
1. What do you guys use to measure the 12 lbs of force you apply when checking the belt deflection? I guestimated the 12 lbs and it appeared that I had 25 mm of deflection (22 - 25 is spec).
Old Nov 18, 2002 | 12:54 PM
trx450's Avatar
I use a good fish scale. I learned the hard way, you can not guestimate the force. Read the shop manual, use a scale of some sort. Good luck!
Old Nov 18, 2002 | 01:15 PM
MuddHound's Avatar
I used a fishing scale and a buddy used a trigger pull scale, use your imagination (not literally).
Old Nov 18, 2002 | 04:43 PM
mudseeker's Avatar
I use a Gates belt tension tester. It's about the size of a tire pressure gauge and is really easy to use. A millwright at work gave it to me so I'm not sure where to get one.
Old Nov 19, 2002 | 08:04 AM
trx450's Avatar
Think I'll ask around the auto parts stores, maybe they have a belt scale. Maybe Gates sells it thru their distributors.
Old Nov 19, 2002 | 07:26 PM
KISSSOFDEATH's Avatar
The belt deflection spec is 22-27mm. If you are getting 25 thats great. After 80 miles mine developed a chirp on take off. I checked the deflection and it was 31mm. I removed one spacer that was .024" thick and the deflection dropped to 24mm.
Jeff Roper
Feb 1, 2022 11:48 AM
blueandy88
Sep 7, 2020 03:11 PM
buddieboy
Dec 9, 2016 05:50 PM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
