Aftermarket Steering Stem / Bar mounts
I have the Anti-Vibe steering stem that Timmy Boy Designs used to put out. Does anyone know what the bar clamp is modeled after. I was thinking about getting pro taper bars. But I would have to change the bar clamp for the pro taper bars to fit. Any one know?
Ask Tim, he's working at TBR Products now so give them a call, either Ryan or Bryan will answer and they will tell you. I'm pretty sure though if you are running Renthals then you'll need to replace the clamps to run Pro Tapers or TAG T2's. TBR can set you up. 619-258-0834
Sep 30, 2015 01:37 AM
