How to adjust/setup American Star Racing A Arms??
How do you go about adjusting the camber and caster angles? How do you measure the angles? Do I need any expensive or special measuring tools? I should have them next week and am going to need some help with them. How long did it take you to adjust the new a arms?
Rockey,
I would go to my local Garage and have them see if they can mount their alignment cameras on your wheels, You could always try to mount a degree finder on a level against a hub and take measurements from their!
Here is a good link that illustrates the measuments that you will be looking for.
Link to Alignment Basics
Originally posted by: jeffnrivercity
I set mine up with 1 1/2 degrees negative camber and 7 degrees postive caster...works great for me.
Jeff
Jeff
I am going to try that or something very close. Do you run 3/8" toe in with that? Thanks
Elkaholic
Sep 6, 2015 02:44 PM
